I am replacing the front door speakers in my 08 G6 with non OEM. I had to cut the connector off. The new speakers are marked Positive and Negative but I need to know which wire from the radio is positive. The factory connection has the dark green wire going to speaker pin marked "A" and a light green to one marked "B". So which would be the positive so I can hook up the speakers correctly?
Probably could use a,multimeter and check the polarity. One will show a reading for a posting number the other a negative. Check out some YouTube video on the subject
Hello i'm looking at the wiring for your speakers and here is what i see, Wire 201 TN/D Go's down to wire 1856-tn sND CONNECTS TO TERMINAL B. A terminal on speaker goes to wire 1856 /YE. tHAT IS WHAT ALLDATA SHOWS AS FACTORY WIRING. NEVER MIND MY TYPING I HAVE ONE ARM IN CAST!HOPE THIS SOLVES THE ISSUES.
