Have replace both Cam shaft postioning sensors after showing a P0013, and the check engine light still on. Does anyone have any idea what this could be. :mad: Still showing a P0013
Its not the camshaft position sensor. Its the camshaft actuator that's sits on top of the motor. There is a sticky in this problems and solutions area entitled P0010 Code/Solution that you should look at.
Have replaced intake and exhaust camshaft actuator solenoid valves and the camshaft position sensor, the car still looses power and lags on acceleration. code was P0013
The actuators run from engine oil flow. check that where actuators mount is not filled with sludge from prolonged engine oil changes.
