2008 Pontiac G6
My recirculation door actuator clicks continuously, so I'm trying to replace it. The service manual says to remove the OnStar module and bracket to get to it, but I can't figure out how to remove the last screw holding the module to its bracket. The screw head is on the back and there is not enough room to use a screwdriver or wrench.
In the below pictures, the OnStar module is on the right, silver in color, with cables coming out of the bottom. Its bracket is gold-colored. The actuator is at the top center, with a black cable running to it with a blue connector and red/green wires. The screw I'm having trouble with is at the far end of the bracket, directly under the actuator.
17764
17765
17766
17767
When I had a similar issue on another car I managed to put a removable screwdriver bit in a small C clamp and got just enough leverage to get it to turn. Not sure if it will help in your case.
2008 Pontiac G6
There is enough room for a wrench behind the OnStar module. Just have to get the right socket length (long enough to clear the module, but not so long it won't fit). I used a 1/4" nut driver bit in a right angle screwdriver with a 10mm nut driver bit in it (one nut driver bit inside the other). I was able to remove the actuator without removing the OnStar module bracket.
