ok...i went inside to pay for my gas (left g6 runnig) when i came out it was off and the service traction control and low fuel was on display. everything turn on fine but not start.. no nothin from starter. i changed battery and starter. now window quit working and ignition thinks key still in even in off position with key out.....ding ding ding fast and car won't lock??????help????
its not giving any codes to check??? when i turn key on there no service light nothing blinking dash just reads low fuel low wash fluid... it originally said service traction control but doesn't now but traction off light is on
Checking for codes is always the first step whether the check engine lamp is on or not. Pending codes do not light the CEL.
My first guess would be a bad ignition switch but the "low fuel" & "low washer fluid" messages really confuse the issue.
So you just filled up with gas with the engine running & went in the store. Didn't open the hood or anything? Has the ignition switch given any indication that it might be failing?
it took twice turning the key to start before i left house but i think i may have let go of key to soon first time. fuel was low so i drove 1/4 mile to gas station i went in the store first to pay for gas.. low fuel was showing cuz it was low.. came back out and it was off and display said service traction and low fuel even after i put gas in it. didn't touch nothin. had it towed home. Im checking codes tomorrow but ignition sounds like its bad. new battery was dead this morning like key was left on
its snowed that day to and traction was working hard. after new battery installed...now windows quit working and ignition thinks key still in even in off position with key out.....ding ding ding fast and car won't lock.
i luv the g6 but this sucks its a 2009 1/2.... only 9 more made after mine... its one of the last ones made.. i live in michigan and still all are stumped.. will see what codes say
