Basic key relearn procedure:
- Insert the key and turn the ignition on. Do not attempt to start the vehicle.
- Bump the starter over by rotating the ignition key to Crank, but do not start the vehicle. Allow key to return to the Run position.
Note the security indicator lamp.It will remain on for approximately 8 to 15 minutes. This is the first password communication stage.
- When the security indicator lamp turns off, turn the ignition key to the Off position. Wait 10 seconds.
-Turn the ignition key to the Run position. Note the security indicator lamp. It may flash for a few seconds, then turn on solid. It will remain on for approximately 8 to 15 minutes. This is the second password communication stage.
-When the security indicator lamp turns off, turn the ignition key to the Off position. Wait 10 seconds.
-Turn the ignition key to the Run position. Note the security indicator lamp. It may flash for a few seconds, then turn on solid. It will remain on for approximately 8 to 15 minutes. This is the third password communication stage.
- When the security indicator lamp turns off, turn the ignition key to the Off position. Wait 30 seconds.
- Turn the ignition key to the Run position, pause momentarily, then turn the key to the Crank position. If the engine starts and runs normally, the VTD Relearn procedure is complete
