Hi everyone
Having some problems and hope I can find an easy solution...
My daughter borrowed and broke down. At the time was told alternator so today the hubby replaced it. Started it up and now service traction and reduced engine is showing on screen and revs high. it ran great up until the alternator problem
Any suggestions? He's flipping out over this.problem
Thanks in advance
It sounds like your car is in "limp mode". There are several reasons why this might have happened. To avoid throwing a bunch of parts at it and hoping something works, not to mention running up the $$$$$, it would be best to retrieve the fault code.
To get the code you need a scan tool or have the scan done at a shop, they'll charge you though. You can pick up scan tools at most auto parts stores. There are several brands out there, Innova is one. Google Innova to see what the tool looks like. They are easy to use.
Once you get the code please post it here and someone will suggest your next step.
