Hello, Just picked up an 09 and when I got it home, I turned the car off and stepped out but the radio stayed on. I've had many Pontiac cars but this is my first experience with a G6. I figured the radio was supposed to turn off when the door opened.
I researched the online manuals and some other online sites and couldn't find any info on this being a settable option. I did find a few people having the same problem, but no answers that helped me. Is this an issue that has a known solution of any kind?
Also, I noticed when checking this out in the car, that when the key comes out from the lock position, the wheel doesn't lock. I can still turn the wheels if I try. Is that normal? If the wheel is actually supposed to lock, then maybe the key sensor in the ignition is faulty causing both problems?
Thanks for any help with this.
P.S. the radio does turn off after about 15 minutes, so the key out timer is working, just not the door shut off.
