My g6 was throwing the money light, so I ran the code and it was the cam position sensor. I replaced the sensor and still the check engine/ money light came back. How do I fix this car ???
Same cam sensor code after replacement I assume? You may have to check the integrity of the wiring between the sensor connector and the ECM.
Yes same code after sensor replacement. I replaced wiring harness to the sensor but I did not check the integrity of entire harness all the way back to the ECM. Thank you!!! I will check that next !!!!
