Im having difficulties installing a HID kit from XenonHids.com. I had them in my previous car so i know they are good quality and how to hook them up, I have the right bulb size and everything. BUT having trouble fitting the bulb in the headlight while still being able to twist the seal cap back on when the bulb is in place. Has any one else got around this issue? how did you set up the light in the housing while still sealing it off from dust/water? is the connection for the light bulb to the capacitors inside or outside of the headlight housing? are you still able to connect the brights after installation b/c brights wires are connceted to low beam wiring in the headlight housing. ANY HELP not sure if it matters but its a 2010, so might have small variations between previous models in wiring?
Thanks!
