41 - 60 of 181 Posts
· Read Only
Just got the wire from you today, thanks man! I'll install tomorrow and let you know how it goes.
I also picked up the "new" style digital climate control that I'm hoping will be a direct swap for the "old" style one. Ended up going with one out of a Malibu as it was $20 vs $250 for one out of a G6 :banghead:
· Premium Member
Discussion Starter · #43 ·
The climate control swap from manual to digital likely won't be a direct fit. The digital system has all sorts of temp sensors and such. Extra wiring involved.
I heard WAMS has stopped doing the tunes and I do not know of anyone else capable of flashing the bcm to the 2010 spec unfortunately.
The new style digital climate control will direct fit as long as you had the digital automatic climate control originally in your car. The backlighting will likely not be red if it came from a Malibu.
I installed an auto HVAC head from a 2010 G6 into my '07 GTP. All the wiring is the same, just had to modify one electrical plug on my harness so it would fit into the new style head. Otherwise all pins are the same.
Sent from my iPhone 6s Plus using Tapatalk
Just bought a 2006 GTP, has the three spoke steering wheel & the multi disk radio that I will eventually replace with Aftermarket. I see everyone who's done this has an '07+ and was making sure I can plug & play or if I need to tweak the BCM.
· Premium Member
Discussion Starter · #46 ·
I know I've spoken with several people that planned on doing the swap in an '06 but no one ever posted a confirmation that it ever worked,
IIRC one of the original people to do the swap before me accomplished it on their 2006 model year.
As far as I see it, if you have the 3 spoke wheel so you can fit the buttons in place and wire in the cluster then it should work.
Since it seems all year stereos can communicate with the BCM, why not all years speedometers?
My 2007 GTP was plug and play when I installed it. Just don't have the manual gear display show up when I switch to paddle shift. I've been planning on going to GM dealer and getting the BCM flashed to answer year to see if it adds the manual shift display in the DIC, but haven't done that yet. I will post an update if I ever get it done.
· 2007 gt retractable
Here is my write up on how to upgrade your G6's speedometer cluster with the 2009.5-2010 cluster with the integrated DIC (Driver Information Center)
This is the OEM option to move the DIC from the stereo to the cluster so that you can run a full sized head unit without losing any factory settings or features. It's way nicer looking than the metra dash kits, way cheaper, and the wiring is actually pretty simple if you already have the factory cruise control.
Side Note: 2005-2009 G6's have a small speaker on the back of the gauge cluster that plays the turn signal sound and all of the chimes and tones.
2009.5-2010 run those sounds through the stereo.
As a result several modules exist to retain those chimes. Some modules also include RAP (Retained Accessory Power) and OnStar.
Here are three modules I found:
Axxess GMOS-LAN-03 Wiring Interface - Retains RAP, OnStar, and Safety Warning Chimes
Metra LC-GMRC-LAN-03 Wiring Interface - Only retains Safety Warning Chimes
PAC OS-311B Wiring Interface - Retains RAP, OnStar and Safety Warning Chimes (I used this one)
Now onto getting ready for your swap.
First you'll need to purchase the speedometer of your choice.
As far as I know there are two designs of the updated cluster with the DIC
and
That one is the actual picture of mine, I couldn't find a good clear one online and I didn't take one before I swapped the needles.
I chose this cluster because it looks just like my old one, The numbers are slightly larger. some idiot lights were moved, and the needles were the same as the other updated cluster, I decided to swap in the older ones to match it better.
As you can see it also lights up White. It's also fully lit up anytime the ignition is on with the lights off.
I decided to tint the backside of the gauge face with red tinted vinyl to make the lights match the rest of the car. It worked out well but makes it a tad darker.
I'll eventually be soldering new LEDs to the board.
You can see the gaps in lighting when the dimmer is turned down.
Once you found your speedometer you need to also get the new Info and Enter buttons so you can control the Speedometer DIC.
This can be found by looking for a 2010 Pontiac G6 Cruise Control Switch (This only fits the 3 spoke steering wheel, Older G6's with the 4 spoke steering wheel will not fit this button)
ACDelco D1952F
You'll also be adding a wire, So you'll need a specific pin to fit the connector on the cluster.
I ended up buying a connector with wires attached off ebay, since I only needed one I'll sell off the remaining wires to whoever else wants to do the swap. Look for it in the For Sale Section.
Here's the pin and wire.
And I had to extend the wire so I had some play room behind the cluster.
I went with green to match everything better.
I have several pins/wires available for anyone wanting to do the swap. Here is the listing for them on ebay
Pin and Wire for Pontiac G6 Speedometer Swap | eBay
Now that you have all your parts ready, You can get all your tools and anything else ready!
You will need:
  • 7mm socket with extensions (I used a nut driver with a couple of extensions)
  • Small Flathead Screwdriver
  • Torx Bits/Wrenches (If not available you can use Allen/Hex keys as none of the screws should be very tight)
  • Soldering Iron (If you plan to solder your wiring connection) (There's only one)
  • Wire stripper/cutter (crimper if not soldering)
  • Heat Shrink tubing or Electrical Tape
  • Little pokey stick, like a toothpick
Let me begin by saying that some minimal wiring is involved. And you have to remove the air bag module from the steering wheel.
I strongly advise that you disconnect your battery and wait a few minutes before starting just to be safe.
If you do not feel comfortable with doing any wiring to your vehicle then I don't recommend you undertake this project yourself.
You'll only be working on one small signal wire.
I am NOT Responsible for any damage or problems that may occur to your vehicle. This How-to is intended as only a guide to help aid you with your swap. Some trim levels and years may be different so I can't be absolutely sure this will work on every G6.
(However, the wiring diagrams from 2005-2009 for the cluster all look identical)
NOW WE CAN GET TO THE SWAP!
We'll start by removing the Gauge Cluster.
First you'll need to remove the Bezel around the Cluster.
To Begin there are two small Torx Screws at the top of the bezel.
There are then two panel clips behind the bezel at the bottom, It'll take a little pulling to yank them out. I tilted the bezel forward so I can reach a few fingers behind it to pop it out.
The two clips are located around where the red circles are:
Then you just need to remove the upper steering column cover, This can be done by pulling up on either side by the stalks
Once removed the bezel and steering wheel column cover can be removed as one piece.
I also pulled the steering wheel as far forward and down as I can for maximum room
will any 2010 cluster work?since i have a v6 do i need a v6 cluster?
· Premium Member
Discussion Starter · #49 ·
I would suggest finding one with the same RPM gauge, Some have a red-line at a different number or stop at 8k rpm or 7k rpm.
BUT one user did swap in a canadian spec cluster in place of his US cluster and said everything work perfectly. So if the speedometer can adjust and work I'd imagine the RPM gauge would too.
· Premium Member
Discussion Starter · #56 ·
It's mostly a matter of how CAN-BUS systems work. They just crap out the same info over the data wires over and over. If you plug anything into those data wires anywhere on the stream that can read that data, then boom it'll all work. Hence taking the DIC from one unit to another, It's the same DIC reading the same info from the same wiring, just in a different location.
I've heard of other users losing the gear listing when in manual mode. Seems to be one lost feature that a bcm update could fix. Though im not sure.
I must've got lucky taking my cluster apart to modify it. I was slow as can be with it.
I broke my stock cluster in no time so I took a lot of time on the replacement
hello cruising6 , i have 2008 model of g6 base. i have install the after market radio and i lost the D.I.C. i have read about using the 2010 cluster for the DIC. what are the list i need to get this 2010 cluster install on my 2007-8 g6 base 2.4
