GXP Owner!
i was also curious about the front bumper...will it fit?
I know you can change a regular G6 into the GXP at least visually.
This is straight from GMParts Direct.
Everything you need for the front end of a GXP
25876635 unpainted front bumper fascia, per the VIN supplied.
25831817 driver's front bumper fascia upper molding, per the VIN supplied.
25831818 passenger's front bumper fascia upper molding, per the VIN supplied.
25831815 driver's upper grille, per the VIN supplied.
25831816 passenger's upper grille, per the VIN supplied.
25831824 passenger's lower radiator grille, per the VIN supplied.
25831825 driver's lower radiator grille, per the VIN supplied.
25831821 air inlet duct, per the VIN supplied.
92119489 driver's front fog lamp, per the VIN supplied.
92119490 passenger's front fog lamp, per the VIN supplied.
What clips does the vehicle require? Where are the located?
22689321 front bumper fascia "V" crest emblem, per the VIN supplied.
25831820 front bumper fascia filler, per the VIN supplied.
I believe this is the list of what you need. Correct me if I'm wrong. I just got this from another thread.
