Ok I Have been running mrr hr1 wheels with a bolt pattern of 5x114.3 since last summer not had a problem even though My 2006 G6 has a bolt pattern of 5x110 I am using the stock lug nuts. Am I missing something??? I don't race the car it is a daily driver.
The 5x114.3 wheels fit on the stock 5x110 hub with no problems? With the stock lugs?!? You crazy!
Any vibrations or noises? Do you check to make sure they are still tight and torqued to the right spec?
I'm actually currently looking to get a set of HRR HR6 wheels. I was going to get the 5x112 and get Wobble Nuts so they would fit and still be tight against the taper in the wheel.
Here's a shot of Wobble Nuts to give you an idea of how they work. Though they should only give you about 2mm of variation, how you managed to slip on wheels that are 4 mm off is crazy!
