2009 G6 2.4L
I need to replace my A/C compressor. Anyone have a how-to procedure?
Basically I need to know if it is removed/replaced from the top or bottom.
TIA
I just swapped mine.
The compressor hangs on one stud with a nut, then is bolted in with two bolts.
From the top I removed the ac lines, electrical connector and nut. From the bottom I removed the remaining two bolts.
I removed it from the bottom and installed the new one from the bottom.
