Hello I have a 07 convertible that has a a/c issue. The a/c compressor will not come on when I press the button. I checked the relay and fuse, they are working, I know because I switched it with the brake relay and fuse which are the same. The relay will not activate or click when in the a/c clutch spot in the fuse box. Any suggestions on this issue?
You could jump the clutch with power and ground to confirm operation.
Clutches rarely go bad, but could happen.
Other possibilty, AC refrigeration issue, no pressure, no allow clutch to apply.
