Maybe this has happened to you. For the longest whenever I go a "certain speed" or higher the metal mesh piece in the front fasica (just above the front "bumper" skirt) always seems to get pushed in from the downforce. Normally what I do is just take a rag (cause you can't use your fingers) and pull it back out to flush, but I've done more than enough times to consider it a peeve of mine. The other day I focused on another GXP as it was turning that had the same issue
Anyone had this happen before and what did you do to fix it?
I don't have a GXP and haven't noticed this issue on my standard issue GT, but I'd definitely tell the dealer to fix it as I'd classify that as a factory defect. They might have already issues a TSB about the problem, I'd check in at the dealer.
If the dealer won't do anything, inform the NHTSA that loose pieces on your relatively NEW car might fall off while driving at highway speeds, and they'll definitely look into it.
