YUP, COULD be the speed sensor which is intergal with the wheel bearing. OR could be a corroded connector of wheel sensor to the main harness(had this on the LF of mine) . OR a broken wire in the main harness. And YES those other systems will be disabled because of the code.
Have fun sortinng it out, as at least you know it's in the RF !
Very much so! Just those systems will not function, you will have NORMAL power braking but nottraction(engine power reduction) or stability control function until the RF sensor cause is found and repaired.
