Last July my AC started blowing warm, I was in the process of replacing my fuel pump (again) and my mechanic said he would throw some freon in for me to recharge the system. That seemed to fix the issue, I had ice cold AC again. I never really run my AC in the fall/winter and now that it's June and I need to use it again it's blowing warm.
Can I safely assume I just need to recharge it again since that is what fixed it last year, or is there any other sort of troubleshooting I should do first?
The issue is that I cannot tell he they just hooked up a can of R134 and put freon in, or if they actually did a full evac and refill, but since it was free I am assuming they just use one of those spray cans. I read up on these cans and it seems that many do not recommend using them, is that true for G6's as well or is it that people just assume they need freon when it's a low pressure switch or bad compressor?
Right now I get like 85 degree air out of my vents when it's 110+ outside so I think the compressor is working since it's colder than it would be if it was just air.
