1 - 12 of 12 Posts
Pontiac G6, 2008 about 48,000. AC won't start in the morning. It takes about 5 to 10 minutes on the road. Once ON, works fine all day. Next day, same problem. Sometimes I get it to about 4000 RPM for about 10 seconds, and the AC comes ON. Took it to the GM delearship, they can't find any problem, freon level is OK, and the AC works all day. next day, same problem. Any idea?
blows warn air, I turn ON/OFF the AC switch, nothing, just warn air (outside temp), then all of the sudden, Plop! the AC comes ON...
Lifetime Member
Are your mornings cool? My first (gut) guess is the relay.
I'm going off of your post for my little rant :D;
How often do folks take their autos to the dealership to have them say, "We can't find the problem"? (I love hassling dealerships with word play.) You could have smiled and reminded them the problem is "the A/C doesn't work" and that they must not be capable of fixing it, hell, you told them the problem!
Then ask them to refer you to a capable service center. You may not get any better help from them but you may have saved the next guy from having to listen to a line of bullshit.
well, it is Texas and it is Summer, so we start the mornings around 75 F or so. However, this might be a good starting point. It is not expensive to replace that relay so I will try that today. Specially, since GM dealership already checked the level of freon and the pressure. Everything works fine after the first "click" in the morning. I will post my results later. Thank you for the suggestion.
Lifetime Member
Good luck!
well, replaced the AC clutch/relay, no luck, same problem. It is very difficult to figure out, the AC doesn't work on the first start in the morning, it takes about 5 to 10 minutes to click. Texas wheather to start in the morning is about 80 degrees F. Once the AC is on the first time, I never have the same problem during the day, until next day. Now, in the morning, both fans are OFF on start, I am wonder if there is a sensor that is telling the AC not to come up because the fan is not ON, but that is normal for any car, at the beginning, the main fan and the secondary fan are not ON to start, unless the car is very hot. However, my other car, when I start with the AC ON, the auxiliary fan comes ON immediatelly. I am lost. Any other ideas are very welcomed.
Courtney :]
My old car (2002 chevy cavalier) did the same thing and it was the temperature gage, seems weird but the "cooling fans" that cooled the engine had control -some how- of the "ac fan" and the cooling fan wasnt registering that it was the right temperature to cool the car which in turn wouldnt associate the air conditioning fan...Seems weird but its just a thought?!
Have you resolved this issue?
Discussion Starter #10
Nop, still have the problem. I just spoke with GM again last week, they were OK and agreed to take a look to the problem, since the car is out of warranty, but depending on the resolution they may or may not pay. I just want the problem fixed, so I left the car on the dealership this weekend, they will work on the issue this week, and we will see if they can fix it or not.
I would be very interested to hear what they found.
Discussion Starter #12
My G6 AC is working again. After two days at the dealership, they fond out that ther is a problem with a "internal valve" on the AC compressor. The delearship replaced the AC compressor and GM was nice enough not to charge. The car has 48,000 and about three (3) years old but out of warranty. This is the second time the delearship replaced the AC unit in less than 48,000 miles. I hope it last another 30,000, at least.
1 - 12 of 12 Posts
