Here is Amp info for 2005. The factory system is 8 channel
Connector Part Information • 15357040
• 8-Way F Metri-Pack 280 Series (L-GY)
Pin Wire Color Circuit No. Function
A L-GN 200 Right Front Speaker Output (+)
B D-GN 117 Right Front Speaker Output (-)
C GY 118 Left Front Speaker Output (-)
D TN 201 Left Front Speaker Output (+)
E RD/WH 1840 Battery Positive Voltage
F BK 1250 Ground
G D-BU/WH 346 Left Rear Subwoofer Speaker Output (+)
H L-GN/BK 1794 Left Rear Subwoofer Speaker Output (-)
Connector Part Information • 12110088
• 24-Way F Micro-Pack 100 Series (GY)
A1-A2 -- -- Not Used
A3 PK 5165 Amp Enable (12V)
A4 BN/WH 599 Left Rear Low Level Audio Signal (+)
A5 BN 1999 Left Rear Low Level Audio Signal (-)
A6 D-GN 1947 Left Front Low Level Audio Signal (-)
A7 TN 511 Left Front Low Level Audio Signal (+)
A8 OG 5748 Amplifier Mute
A9 D-BU 46 Mid-Range Right Rear Speaker Output (+)
A10 L-BU 115 Mid-Range Right Rear Speaker Output (-)
A11 BN 199 Mid-Range Left Rear Speaker Output (+)
A12 YE 116 Mid-Range Left Rear Speaker Output (-)
B1 L-GN/BK 1794 Right Rear Subwoofer Speaker Output (-)
B2 D-BU/WH 346 Right Rear Subwoofer Speaker Output (+)
B3 -- -- Not Used
B4 TN 1946 Right Rear Low Level Audio Signal (-)
B5 D-BU 546 Right Rear Low Level Audio Signal (+)
B6 D-GN 512 Right Front Low Level Audio Signal (+)
B7 L-GN/BK 1948 Right Front Low Level Audio Signal (-)
B8 -- -- Not Used
B9 TN 1856 Left Front Tweeter Speaker Output (+)
B10 YE 1956 Left Front Tweeter Speaker Output (-)
B11 L-GN 1852 Right Front Tweeter Speaker Output (+)
B12 PU 1952 Right Front Tweeter Speaker Output (-)
