1 - 20 of 110 Posts
i have tried to read as many threads as i could lol...but the answers i am looking for werent very clear to me.....how would i go about adding a 2 channel rockford amp to power 2 10"subs?..i wanna keep the stock deck, but just add some bass......i have read about the remote wire hook up, just not quite sure about the inputs for the amp itself.....being RCA jacks on the amp, is there a way to add this to the monsoon system?....thanks for any and all help!:beer:
add a sub
it isnt hard at all 1st you need to get a converter to splice into your 6x9s speaker wire to rca, you can buy this at circuit city or and audio store, then just run your amp cables as normal. the only thing that you will have to find on your own is a remote wire, get a light tester and find something under the dash or on the left side of your trunk that only has power when the car is on. hope this helps
These car manufacture's have improved factory sound but is still limited. And it all start's at the head unit. It made to protect your factory speaker's. So when you hook up an amp to the rear speaker's it's controlled through ur head unit and is highly influenced by the bass and treble controls. Your best bet is to purchase a sound processor. I bought the MTX re-Q and it's a miracle worker. Right now Crutchfield.com has it cheaper than when I bought it from there but it's the same one. Even though it's inexpensive it's really good. I'm used to have the big 12's and 15's but since I bought my 07 g6 I didn't want a huge box limiting my trunk space. So I bought the powered Visonic 12" sub that already come's in a box with an amp from walmart(yes walmart). It's only rated at 250 watts, but that's RMS power which is true power. I only have one cause my wife dosen't like the big bang but it's still a good choice especially hooked up to that sound processor and the woofer is only 50 buck's already installed in a nice box and the amp built into the box as well. You can very easily install two. You still need the wire coming from the batt. for each one but it's a good inexpensive to go.
I just had tweeter install my kenwood amp and 2- 12" JL's I got in and couldnt figure out why the base was at like negative 6, then the sirius powered up and I found out why, unlike with my last 2 cars that the subs were in I decided to leave the factory head unit in this one. It sounds good, you just have to fool around witht he base, treble, mids, and f-r fade, as for which cables to use..... I get lucky that one of the girls I work with at the bar has a husband who installs at twetter, so I take it to him and he knocks a little off the price, plus its warranty work so if there is an issue I take it back to them.
amp
ok, i have a amp with the remote gain on it so i am not that worried about the head unit distorting it which it should not if i use the rca converter?
the one question i have is, does anyone know which wires off the back speakers are pos or neg.....i have not looked under there yet,,,,,,any help would be greatly appreciated.
· GTP 06
Alright, I've put it all together and added a sub to my factory radio. This link shows you the pictures in steps. I've tied on to the car's power and high input to the amp. I've made a handy quick connect to take the sub out if needed. I added a capacitor to take the load off of the smaller power wire. sounds great. I've bridged the amp to put out about 200 watt. Remote wire is the small pink wire with the red wire tie to it. You can get the wiring diagram from crutchfields web site by searching for pontiac.
http://kevinandjamie.servegame.com/pictures/g6 audio/
I just put a sub in my car about 30 minutes ago.
The first thing you need is a Scosche Level Converter. You can get one of these at walmart for $18. Next you have to splice wires into your rear 6x9's and run them to the Level Converter. IT DOES NOT MATTER WHICH IS POSITIVE AND NEGATIVE! then you just hook up the amp and sub like normal. Except the remote wire. you have to hook this into a fuse. i used the Hvac Ignition one. its located on the right side of the center console. you just stuff the wire in one of the fuse holes and put the fuse back in.
· Dustin
just put a solo l7 12 in a ported box in my trunk with a kicker 1200 watt mono amp... so much bass... lol... only prob is now my fm stereo will only pick up local channels anything i used to pick up is now static does anyone know what i messed up by putting an amp in? oh yea i didnt pull the cd player out i used a line output converter
well you could change the deck but when you do you lose all ur d.i.c controls such as oil life rest and ext. you can buy a costly kit but yes just run the power wire as normal and then run the remote wire off a fuse in the fuse box that only comes on with the ignition and then the line output converter from ur 6x9s then run the rcas to the amp. its reall simple if you have any wiring question feel free to ask
· Heavy Modder
i have an 06 G6 GT with the Moonsoon, was wondering if there were indeed RCA jacks on the back of the head, and if not would it make a sound quality diff to use the adapter to splice into rear speaker wire?
· Southern 6 GT
ok sooooooo on the monsoon amp wiring diagram on crutchfield...the pink wire is the remote turn on? correct? so i could tie into that for the remote wire on my amp?
· newcomer
http://www.kevinandjamie.net/pictures/g6 audio/
just wondering if your car has the same system and wiring with mine.. Is it really that easy?? just get some wiring done from the trunk? i'm buying a used sub, a used amp, and subbox.. what would I need after that? thanks in advance..
1 - 20 of 110 Posts
