Alternator ratings are al follows: (rated/load test output)i thought it was more like 115A but i really have no idea. I'm currently running a 1600W amp at 800-900W for my sub and a 127W at 60-70W amp for my speakers and have minimal light dim on the stock alternator and stock battery
What Size of amp are you running that makes it heat up that much? and do you have a capacitor? and for Tay Tay have you checked out if your car heats up with your 1600 watt amp? Our cars have a pretty big alternator, if you have a decent size battery to take all the recharging we should be fine. If you keep the lights off in the car and keep the dash dim down try and reserve as much power as possible and you should be fine but let me know how hot your car is getting because I am most likely going to get a 1600 watt amp aswell.does the dash feel hot, feel the face by the ac buttons...if thats hot after a drive then yes your pushing to much power through there.
in my car my deck heats up and restarts...
what about light diming?i got a 1600W amp and it barely heats up. Just depends on the one you get because my 4channel amp heat up alot.
My dash (stereo and AC buttons) has heated up ever since I got my 06 G6 GT. That's with stock everything.there is some. but its very minimal. i only notice it when im parked close to a wall or something. btw, your dash shouldnt be getting hot if your amp is in your trunk. seems as though something else is wrong.
ha true sorry man, my budget is 150 dollars total so like after shipping and border fees, i know its pretty low but im a poor 17 year old with a nice first car lol.How tight is your budget? The first one seems pretty good. Hard to recommend you other amps without a budget![]()
the W1 isnt any better than your type r so i would just keep it.
with your tight budget you best bets for an amp are likely one in the link you had. Or something like these:
Power Acoustik CPT1 1500
Kenwood KAC 8104D
Power-Acoustik CPT1 2000
If you'd be willing to spend $150 before taxes and all that stuff, i would recommend this amp. Hifonics HFi1000D. IMO its worth the extra $$ over the other ones i have given links for. It will be a better quality amp aswell.
If you want a different sub, i would just wait a bit and buy a JL 12W3 when you can afford it. My buddy has one and it pounds plus sounds amazing.
okay thanks then ill keep the alpine, and there out puts too small the amp and the sub would just heat up, better to over power then under power a subforgot to respond about those subs. i personally wouldnt go for them. At least not without hearing them first. I was reading some forums about them, and there seem to be some negative opinions on them. mostly about the quality not being so good and them not lasting long.
BTW. all of those amps i posted would work with your type r. i wouldnt have posted them if they wouldnt![]()
