Its there on my 09 aswell.
I don't even want to look again on my 08, as I will feel like a real DOPE if I have that larger gromet as well!!:bawl:
Question for you guys:
What single sealed 12" sub would you recommend for this amp? I'm looking for sound quality over pure power. $500 is about as much as I want to spend.
Alpine MRD-M1005
Mono subwoofer car amplifier
500W x 1 RMS (4ohm, 12.0V, 1% THD+N)
700W x 1 RMS (2ohm, 12.0V, 1% THD+N)
700W x 1 RMS (4ohm, 14.4V, 1% THD+N)
1.000W x 1 RMS (2ohm, 14.4V, 1% THD+N)
Max. 1.800W x 1
S/N Ratio 90dBA
Internal, variable-speed cooling fan
Amp Link for single-cable hookup to compatible Alpine receivers
STAR Topology for cleaner sound
Bass Engine® features:
Low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope
Selectable subsonic filter (off, 15Hz, or 30 Hz)
Parametric EQ variable from 30-160 Hz, ±12 dB
Bass Compensator enhances low-end definition
Top-mounted digital control center with cover
CEA-2006 Compliant
MOSFET power supply and output stages
Preamp outputs
Time correction 0-10 milliseconds in 0.1ms steps
Phase adjustment 0-180
Turn-on delay
Requires 4-gauge power and ground leads and 80 amp fuse
Extra-large terminals
Fuse rating: 20A x 4
Dimensions: 13"W x 2-5/16"H x 8-11/16"D
Thanks!!:beer:
