2007 gt retractable
im tired of my oil light coming on after driving awhile and then going back off without the rattling that coinsides with no oil pressure.has anyone added an oil pressure guage and where did you put the sender?and yes i checked the oil level.
Have you checked the oil sending sensor its on the front of the engine on a 3.5L and they tend to leak from the connector where it connects on the sending unit sensor. Unplug the electircal connector and if oil leaks out replace it they crack inside from the heat and the oil might be causing your problem. Clean the connector and plug it back in. Mine was leaking from there and its easier to do if you remove the starter.
