Is there a way to add variable timing to the G6's other than the 09 g6?
I think it'd be too much of a PITA to do. If you have the time, money, patience and are out of your factory warranty or have high miles on the current engine, then at least it's a project that'll keep you busy! Cheers.Is there a way to add variable timing to the G6's other than the 09 g6?
I agree with this, a true VVT would require the cam shaft to move or an aux (for the lack of a better word) cam lobe per cylinder. This IMO is a major mod that would be, as stated, a PITA for a daily driver. Please, if I'm wrong let me know.I think it'd be too much of a PITA to do. If you have the time, money, patience and are out of your factory warranty or have high miles on the current engine, then at least it's a project that'll keep you busy! Cheers.
Yo do this via "TUNE" ?Variable timing or Variable VALVE Timing? Variable timing I can do in the calibration![]()
valve timing is pretty much what you do when you've got mods done to your car. you can advance/retard the timing to get more power at higher rpms. usually turbo/NOS cars retard their timing and vise versa for the NA/no bottle builds.I agree with this, a true VVT would require the cam shaft to move or an aux (for the lack of a better word) cam lobe per cylinder. This IMO is a major mod that would be, as stated, a PITA for a daily driver. Please, if I'm wrong let me know.
You could buy a Pintowith the I-VTEC. (Like me
The original question.Is there a way to add variable timing to the G6's other than the 09 g6?
Just so I'm getting this straight; a tune "tunes" the existing timing of an engine to optimal performance levels with reference to stock timing.valve timing is pretty much what you do when you've got mods done to your car. you can advance/retard the timing to get more power at higher rpms. usually turbo/NOS cars retard their timing and vise versa for the NA/no bottle builds.
so yes, you do this via tune. it pretty much has to do with when the plugs fire.
I want to be clear that this is simply a terminology issue on my part and not some new technology I’m not familiar with. I’m not trying to call BS or anything like that, I’m just being sure I understand the question because I’m under the impression that all cars on the road have an ignition system with variable timing.Is there a way to add variable timing to the G6's other than the 09 g6?
I guess my answer would be, I don't know if that would be an available mod for your engine. As some members have stated they have a G6 engine that has VVT I would assume it's a possibility. But WOW, that's a whole lot of work.This is what the question is:
Im talking about getting dirty and replacing the cams with a two-profile cam which is V-TECH and of course all the electronics to make it work. Read this whole page and i want to see if its possible to add V-TECH and VVT to optimze performance which both together is called i-VTECH. So my question is Can i add either/or V-TECH, VVT, or i-VTECH to my engine? Whats possible and not possible?
Read here:
http://www.valvoline.com/car-care/automotive-system/engine/dsm20040901vt
Of course this is a major mod, but im just curious.
If one wants it badly enough, it'd be easier to sell the current car and purchase one that has the tech, but really, I'd stick with what works, as GM has done for the last half century: pushrod engines. Even the new 3.6L world engine is too high tech that I probably wouldn't want to tear into it even if I had to!yeah, it would probably be a lot of work and money. you might end up needing a new computer, cams, heads that are made for the VVT or v-tech or i-vtech, and the parts to make the cam adjustments.
