Having issues with the convertible top leaking if i look at the seem up front where it latches it is wider on driver side where its leaking in carwash need to adjust drivers side to close that gap anybody have any ideas how to adjust the roof whis is causing the trunk to pop open when i push button to open roof and the latch doesnt hit the switch completely because of the allignment issue thanks in advance
Are you handy?
I was up in the headliner and noticed that at the front edge you have the latches.
Open the roof, and stop it when the panel lift arms are vertical.
Roof will stay up a while with engine running.
Do NOT leave hands in between any moving parts.
Pull the retainers around the latch.
This is where I need to be at my car to see.
I recall the cable having an adjuster nut.
It should be a matter on loosening the nut, tightening the barrel, and tightening nut.
I would need to fiddle with my car to confirm, unless you want to take a whack at it first.
Photo from YouTube, and this guy talks about it around 11:00 but doesn't show it.
