No idea where to put this, but i figured I'd throw it here because it can help with maintenance.
Picked this up a while ago. It rocks. It has a crap load of PIDs and is pretty informative. Does 1/4mi, 1/8th mile, 0-60, crank relearn, etc. etc. as well. Very nice unit. Blends perfectly with the rest of the red dash too.
i've since moved it to one of the vents above my radio because it's easier to use and read from that position. Also I am adding an AEM wideband eventually and the two of them in the two vents above my radio will look sickly.
Discussion Starter · #5 ·
the aeroforcetech makes the gauge.
www.aeroforcetech.com
The pod to put the gauge in is made by Elbow's High Performance.... Jim is the guys name and he gave me a prototype to show to people. I'm hoping to have him on here pretty soon as they're about to go into mass production.
http://www.elbows-highperformance.com/
Aeroforce Interceptor Gauge
http://www.aeroforcetech.com/index.html
The Interceptor is a gauge that measures 52mm/2 1/16inches. It plugs into the OBD2 port. Comes in a variety of different colors selected at time of purchase (face color, bezel color and display color). It looks like this:
Listed price of $239 for single, $399 for dual (my assumption is its by 2 get them cheaper?)
not all of these are specifically applicable to our cars as we may not have the sensors stock. but as they have listed...
PARAMETERS:
 RPM
 MPH
 INTAKE AIR TEMP
 MASS AIR FLOW
 ENGINE COOLANT TEMPERATURE
 INJECTOR PULSE WIDTH
 DIRECT INJECTION PRESSURE
 INJECTOR DUTY CYCLE
 COMMANDED AIR/FUEL RATIO
 AIR FUEL RATIO (FACTORY WIDE BAND O2)
 ACTUAL LAMBDA “ “ “
 LONG AND SHORT FUEL TRIMS
 O2 SENSOR OUTPUT
 MANIFOLD PRESSURE (inHg/psi) “boost” gauge.
 MANIFOLD ABSOLUTE PRESS. IN kPa
 IGNITION ADVANCE
 KNOCK RETARD
 TQ MGMT SPARK RETARD
 ENGINE RUN TIME
 BATTERY VOLTAGE
 TRANSMISSION TEMPERATURE
 IDLE AIR CONTROL COUNTS
 THROTTLE POSITION PERCENTAGE
 THROTTLE POSITION VOLTAGE
 ENGINE LOAD
 OIL PRESSURE
 OIL TEMPERATURE
 FUEL PRESSURE
 FUEL PUMP DUTY CYCLE
 INTERCOOLER OUTLET TEMP
 MISFIRES
 TRANSMISSION TORQUE, SLIP SPEED.
 SHIFT TIME
 PLUS MANY MORE!
FEATURES:
 Logs displayed data for approx. 1 minute when selected
 Calculates instantaneous and average fuel economy, engine hp
 Programmable high intensity LED’s to warn when a parameter exceeds a safe level – can be used as a shift light.
 Calculates 0-60, 1/8 mile, and ¼ mile times.
 Bi-directional controls (fans, fuel trim reset, CASE Learn for GM)
 Contains 2 analog inputs which can be configured to read any 0-5v DC signal.
 Can read and clear diagnostic trouble codes.
 Programmable “cyclic scan” where up to 8 parameters can be selected to cycle automatically on the display.
