I own a Pontiac G6 2007 6 cylinder I was having a problem very minor but serious where I would be driving in my RPM would go up-and-down by about 200 just to down up down a few times or I would drive highway and the rpm would drop just a bit almost not noticed if it was some1 who didnt kno my car. Well I done massage air flow Sensor change I changed fuel pump air filter u name it. So I went to change my Coolant air temperature sencer so I did, but as you already know this car has no petcock so I cant drain coolant properly. it drained from the CTS witch is fine just that I put the new 1 in and I started putting new coolant in the Reservoir the cat was on so I could let coolant go down then refill i only filled it once while waiting i deleted the codes that was on and as soon as I did that the cars rpm went sky high so high I had 2 shut it off then now it wont start I waited 2 days checked 2 see if coolant was gone so I could refill but it only went down maybe less then half. I started the car and it sounded like it would die then rpm up then almost die then rpm up did that for a hot minute I put the car drive and I could feel motor jumping. What the hell is my problem
