I'm needing some assistance. I recently purchased a 08 Pontiac G6 from a coworker of mine. Problem is, its a value leader and didn't come with cruise control.
I found online a Rostra Cruise Control kit and picked it up. http://www.redlinemotive.com/part-number/rostra/250-1775.asp
Installation Documentation Reference (http://www.rostra.com/pdf/Form4909C.pdf)
It mentions in the installation documentation to connect Red harness wire to "Accessory 12 Volt" and Blue Harness wire to an "Accessory Power Source".
I understand what the "Accessory 12 Volt" is but what is an "Accessory Power Source"???
I found a how-to from an owner of a G5 who installed same kit and in his he references that he combined the 2 wires and just wired it to a single 12 volt source, in his case the ignition 12-volt. (source http://www.g5club.net/forum/showthread.php?t=1245) Are the 2 the same? Only difference in a G5 is you have to have it dealer enabled where as with G6 you don't.
Any help would greatly be appreciated. Once i figure it, I'll most likely post how-to images with instructions.
