This only happens occasionally, but it's pretty annoying when it does. Everything I've found through my own research says it does that if you lock it with the keyless remote and unlock with the key.
However, I don't have a keyless remote, so that's not my situation.
Any suggestions?
Well, Before I had the chance to fix my key Fob(Battery hold down needed to be resoldered), I had to use just the key to lock/unlock. Whenever I would unlock with the key, the alarm would go off. At least on my car, whenever you lock the car using the electric locks on the inside and then unlock with a key, the alarm will go off. When you use the remote, it turns off the alarm at the same time, as for the key it ONLY unlocks the car. Why it only goes off sometimes is another question...Mine went off whenever I unlocked with the key..Good luck! I would imagine you could change the alarm settings through our lovely radios. I know there's an alarm setting in there but not sure exactly what it does because I have a Double Din installed in mine :p
