My 2006 G6 has 120,000 miles on it already, and I'm curious if anyone knows how many miles this thing will probably go......
I didn't think you were supposed to mess with the trans fluid in these cars? Also, my pads/rotors only last a year tops, how do yours last 100k miles? The rotors are so small for this car.200,000+ if you keep up the matience and as many as you have I'm guessing most of that is highway? You will be fine
Lest of matience you should have done buy now
Flushed coolant
24 oil changes (at every 5k)
Trans fluid change
Brake fluid change and you should be on set number two of pads & rotars as well
Tires rotated or hell you should be on set number two.
Spark plug and wire change
You should haved greased all door Hinges.
Do all of these things is preventive matience,this will get your car up there. IMHO this is the problem with today society there too lazy to do it themselves. and hell i'm young
At what mileage? Can I do it myself? I don't see a way to drain or fill my tranny. 2010 4cyl.You definitely have to change your tranny fluid. I went with aftermarket rotors and have about 100,000 miles on mine. Pads need to be changed regularly.
My 2007 G6 GT is pushing 240K miles (at 239+) at the moment. Regular maintenance and a couple of things here or there, but overall not too bad for 240K miles. Been driving it since brand new.My 2006 G6 has 120,000 miles on it already, and I'm curious if anyone knows how many miles this thing will probably go......
