Michigan G6er
prep the surface very well. use fine sandpaper or emery cloth then wipe the surface off to get dust off. then apply very light coats until the desired tint. I would not go with more then 4 light coats otherwise its too dark. then let dry in between all the coats then put a few (2-3) coats off clear. good to go. just take your time and do it right. I would also tape off your reverse light otherwise it will be too hard to see backing up.
