1 - 17 of 17 Posts
What ATF has everyone been using? Regular or Syn? and what type/brand? I was thing about flushing the ATF since the trans is shifting somewhat hard at times. The car only has 17k miles on it, but I'd like to change the fluid soon. Is the stuff they use at the dealership good enough?
Dealer told me that ATF flushs are not recommended. Only a pan drop and drain. Apparently there are some issues with the trans when flushing out all the old fluid. Any thoughts?
· Lifetime Member
Some years back I had a very reputable transmission repair shop tell me “unless absolutely necessary, never drop the trans pan for a fluid change.” I’ve stuck with this advise. He also said not to flush the fluid, a simple fluid change is always best.
you dont need to change your auto-trans-fluid until 50,000 miles... just letting you know, even with hard driving it will be good up to then...
1 - 17 of 17 Posts
