1 - 20 of 74 Posts
Lead Foot
G6 owners rejoice! I found a cheap way to add a quality auxiliary input to a stock G6 headunit! I bought and installed a
and it works great! Basically you plug youre car's antenna into the Modulator, and the modulator into the headunit. Because it is hardwired, it allows for much better sound quality than a wireless transmitter. It isnt quite cd quality, but its pretty good considering the price.
How-To:
Several People expressed interest in the modulator, so i figured a how-to guide for the G6 couldnt hurt. First off, along with the modulator unit, G6 owners will need antenna adapters because GM vehicles use a micro antenna fitting (
). You will need to remove a good portion of the dash to get at the back of the radio, so [ame]http://www.g6performance.com/phpBB3/viewtopic.php?f=29&t=5991[/ame] is an excellent tutorial (its a life saver).
After the dash is opened up, find a suitable place to install the modulator. I used double sided tape to stick it in with the fuse box (below and right of the radio). After the modulator is mounted, run the antenna hook-ups behind the radio, hook the modulator into the antenna and headunit using the adapters. Tuck the wires down behind the radio - dont worry, theres plenty of space.
You can see in the picture below were I located everything, and how I wired the power.
In the G6, the fusebox is located conveniently close to the radio, so running the wiring was a breeze.
Now connect the black wire to the frame (see above, bottom right), [edit] and tap (or tuck under) the red wire to the A/C fuse so that it will cut power when the ignition is off. The modulator comes with a 2 amp inline fuse so you dont have to worry about burning it up.
Now that the antenna and power is hooked up you need to find a spot for the power switch and 1/8" mini plug. The unit comes with a nice little housing that can be stuck in a good location, but i wanted to hide mine, so i installed the power and mini plug in the top of the cubby just below the A/C controls.
Now youre pretty much done, but before putting the dash back together, test the system to make sure it works! The modulator can be set to broadcast on 87.9 and 88.1 FM (if i remember right), so pick whichever you want to set the radio to. After youre satisfied that everything works, put the dash back together and youre done! Here are some more pics of the modulator and my finished product.
Thanks for reading :D! Let me know what you think and dont hesitate to ask questions if I didnt explain things well enough :glasses:
EDIT: I found that I was getting some interference when I cranked up the A/C. I looked an noticed that I had the wiring routed up against the A/C electric fan housing (behind the head unit), so I rerouted the wiring further away from it and the audio is clear.
Just ordered all the parts, should have them this week!
I was just wondering, what is the easiest way to pull off the dash around the deck?
Lead Foot
here is the how-to guide i used in removing my dash - it was a life saver! http://www.g6performance.com/phpBB3/viewtopic.php?f=29&t=5991
FM modulation...? :confused:
How much are all the parts?
i paid $30 for the modulator and $16 for the antenna adapters, all from amazon.com. links are in the first post^
Lead Foot
Hmm, If you were to go through all that trouble, I would just put the hard wired version in.
mmm im not sure what you mean... it is hard wired. if you mean replacing the head unit, there are several reasons why i didnt: cost and loss of the computer display, mainly.
GTP 06
There's a kit that plugs into the 12 pin connector on the back of the radio. When you press the SRCE button under volume. It changes from Radio to CD to AUX if its plugged in.
Lead Foot
Discussion Starter #8
oh, well... dang it. could you plost a link? i have a suspicion that my route is cheaper, but i will have to keep that in mind.
Your route is cheaper, but you don't really rule out 100% static. If you pause the music some how and crank it up, you'll hear a hissing sound.
here ya go.. http://www.discountcarstereo.com/detail.aspx?ID=446
Does this method charge while playing? I have an older iPod and the battery is crap. But if I can find something that will connect via the dock connector and charge it while playing, that's a win.
when you go to order it it says it isnt meant for the g6
This looks pretty cool and seems like a cheaper way to get an aux input rather than buying a new head unit. Has anybody ever gone this route with the G6 or installed it before?
GTP 06
Think that depends on if you have monsoon or not. they probably don't include the G6 because if its not the monsoon it won't work or something. People getting mixed up..
alright....well i got the monsson, maybe ill order it and make a weekend project out of it....now where to mount that huge box and inputs...?
Talked to the customer service at discount parts direct and here is the link for what would work for a 07 GT with monsoon and no xm
http://www.discountcarstereo.com/detail.aspx?ID=1246
From what i understand if your car totally doesnt have sat radio (what it works through, i think :confused:) then you have to go to the dealer and have them activate it....other wise looks like it should work fine, has a one year warranty and can be returned if it doesnt work. If you search "PXAMG operation in 2009 pontiac G6" on youtube they have a demo
Talked to the customer service at discount parts direct ...
if your talking about GMPARTSDIRECT.COM then I call BS.
They have no service. Thats how they are so cheap. ZERO customer service....
Oh wait a minute.....they dont have your money yet do they? Order and then call them and see how they treat you.
I freeeking hate them. They suck. The parts are cheap and good but if
you have a problem you are SOL. :mad:
Pay attention to the screen with small print that you have to hit accept to order. READ what it says. The cliff note version is:
"I give up all my rights and agree to get screwed and do not hold GMpartsdirect lible for anything they do"
well i ordered the device yesterday, shipped out today:D
I'll yet ya'll know when i get it and how it works
Received the product took apart the dash installed it and.....it didn't work. Turns out I have an 07 monsoon stereo without xm and the product needs the xm port to function (the rep gave me the wong info.) so looks like for my situation I would just have to go the route of getting a new headunit with an aux. If you like the look of this system and the fact that its cheaper than getting a new headunit, make sure your vehicle IS XM CAPABLE
1 - 20 of 74 Posts
