couple days after having and oil change i started smelling coolant after watching the overflow tank which seemed to be the source of the problem i could see where coolant was dripping under the tank so i replaced the tank filled the system up with dexcool continued to see the tank go down but could not find a leak other than the overflow tank again took it in for a pressure test after a hour and a half they found that my rear head gasket was leaking the coolant was evaporating so there was no leak and the leak in the head gasket was just starting so the engine temp was running normal
thank god for a warranty!!!
