okay so im going to be doing a little project with a tailight.. dont want to spoil to much... but i need to break the sealant on the them... so best way is to bake them right?
does anyone have a recommendation on what temp and time that would be good to be able to pull apart,?
also, what is a good brand sealant to use once im finished
no need to bake the tail light, there is no sealant the pieces of plastic are sonicly welded but came apart easily on the sedan tail light i took apart, and to seal them back up id just use some 2part plastig epoxy but beware ones u seal them with that you wont ever get them apart again without breaking them
so how difficult is it to take apart then? i took a look at my tail light and i could have sworn that there wa sealant around it... and im jjust a little confused on how you take it apart.. just rip like peel it?
i just went around it with a small flathead screw driver and carefully pried it apart....
well according to the tracking # it should be here around tuesday, so im looking at doing this thursday?
is it supposed to look like there sealant? i could take a picture of my tailight now... but is there a certain spot i should start prying it off at?
