I have had my radio act up in the past, and needed to turn the car off and then back on to get it to work...and now the wipers (which I am sure are controlled by the BCM). Just wanted to pull the connector, spray a little contact cleaner, and then add some dielectric grease to see if that takes care of this.
The BCM has 4 connectors. Just be very gentle & you should be ok. Pull them straight off. Pull the batt neg cable first.
