401 - 420 of 444 Posts
i like it. i wonder if it will work on the 2.4L with the plastic engine cover still on....
I know the oil cap on the 2.4 can be removed from the spacer and placed directly in the valve cover, if the metal cap has the same bottom then It should fit. I know ZZP sells a billet oil cap for the 2.4
what paint did you use for the interior panels? I know I probably asked before and I just can't find my posts in your thread. also how did you remove each panel? i'm trying to find little things in the car to paint lol....and how do i remove the air vents so i can paint them also? (not sure if you painted your vents...) and what kind of sand paper and primer did you use? i was thinking about using the same paint as you seeing as how its the same color as my car. i'd like to do the shift plate also but i'm thinking too much of a hassel for the time i have (i probably have time...just lazy and dont feel like trying)
and also...the engine covers...did you use VHT spray paint?
