I feel totally dumb for posting this, but I am a "first car" owner, and still have lots to learn. Feel free to move along if this is too lame of a question. I don't think my block heater is working. Is there a way to test it?
The low tech method is to just listen to them. Block heaters draw a lot of current & you can hear them click on when you plug them in. After they are plugged in they make a percolating noise. You can also feel the heat they produce. This diagram should help to locate it if you haven't yet:
http://www.g6ownersclub.com/forum/attachment.php?attachmentid=2679&stc=1&d=1325924665
If the element burns out they aren't expensive to buy. They often break in the wiring or plug.
If you have a multimeter, the resistance across the hot & neutral prongs should be around 15 ohms. If its infinite, there's an open somewhere.
