2007 Pontiac G6
Can anyone tell me the bolt torque for the front lower control arms.
Needed,
Front bushing bolt:
Rear bushing block bolts:
Ball joint pinch bolt (in the spindle assy):
3. Tighten the ball stud to steering knuckle pinch nut to 50 N·m (37 lb ft). Reverse the nut 3/4 of a turn . Tighten to 50 N·m (37 lb ft) + 40 degrees. Tighten the nuts and the bolts with the front suspension loaded by using the proper jackstand.
4. Tighten the front bushing to frame bolt to 50 N·m (37 lb ft) plus 90 degrees.
5. Tighten the rear bushing to frame nuts to 50 N·m (37 lb ft) plus 90 degrees.
