Hey guys, my first post. I been on Grandprixforums alot. I have had over a dozen of them, but a year ago I ended up buying a 08 g6 coupe.
There has not been very many problems in the 20K miles i have had it. It just hit 103K miles.
I ended up putting around 600$ into the suspension, a whole front end, brakes everything but the cv axles and the inner tie rods.
My problems came about around 1k miles after the work.
I ended up putting the brake rotors that were supposed to be the non abs model. I bought a new set of brake pads and rotors, put them on. They squeek alot! Its not so bad once i get a couple miles down the road, but if i dont push the brakes in over 1/3-1/2 way down, i get squeeks constantly.
I did not add brakes quiet to it, the rest stuff. I also forgot to re-lube the pins and once i did the brakes i hit the brake pedal and the car pulled to left very hard.
My problem is, will adding brake quiet and re loobing the slider pins on all 4 tires fix it? I got the correct pads+rotors this time, i think they were 11.65 size.
I want to get this done before I bring my car in to do the fluids. I hate doing fluids, and gaskets. Everything else i love doing. I also get this weird clunking noise when going slow over bumps. No noise at highway speeds, or even over 20 MPH. Its not loud, just a very faint clunking noise like the sway bar links are loose.
Im going to be working on it on monday. Figured someone here would be able to tell me if i am on the right track for the brakes. Going to cost me roughly 180$ to do OEM brakes on it if the pads+rotors are the problem for some reason.
Discussion Starter #2
I should also say, that it has been 8K miles since the brakes were done. They started making the noise in less than 100 miles after doing it. I thought they would quit, but it seems to be getting louder and more constant. I am a guy that wants his vehicle at 100% and it bugs me when something is wrong.
