101 - 112 of 112 Posts
I can't figure this out. My brake lights and rear blinkers don't work but my tail lights, center mounted brake light and reverse lights do. I've replaced the bulbs, the fuse and, now today, the relay and nothing has worked. In reading through previous Internet searches, I've learned of a common issue with the g6 model is the brake lights staying on and going off when the brake pedal is compressed. This is now happening with my center mounted brake light and I'm just at a loss now so any help would be greatly appreciated!
I had the same problem on my 07 G6 a few years ago. Had the dealer replace the brake light switch and the next day it was doing the same thing. Took it back and they fixed it. Said the new switch they put in was defective. NOT!!!!! A year or two later around 2013-14 I went back for a recall and also I believe there was a recall for the brake light problem. I had my original paperwork and they had to refund me the $140 I paid them to replace the brake light switch. The problem I believe if memory serves me correctly was a BCM ( Body control module) which I believe is inside the console on the passenger side behind the access door. I believe it has to be cleaned of corrosion and sprayed with Dielectric grease to cure the problem. Here is the recall # for this service13036 Attached are pictures of the recall letter. Good luck
Brake light/Cruise control problems
There was a recall issued for this problem. The recall # is 13036. I had paid for repairs which did not solve the problem before it was issued and they had to refund my costs and repair the problem again to fulfill the recall. Attached is the letter with the recall number and what they are going to do to it. here is the Consumer Reports explanation of this issue also
https://www.consumeraffairs.com/new...vehicles-with-electrical-problems-051614.html
Also seen this in that reports comments. Take it for what its worth but it says it is covered now for 15 yrs or 150K
I just received a notice from GM (March 2017) identifying this issue, associated with my 2007 Pontiac G6, but it is not identified as a recall. The letter states in underlined bold print "Do not take your vehicle to your General Motors dealer as a result of this letter unless you believe that your vehicle has the condition as described above." The letter then states that GM is providing additional protection for this condition to include coverage for 15 years from the in-service date or 150k miles, whichever occurs first. An attachment entitled "GM Product Field Action Customer Reimbursement Request Form" is provided.
It seems that GM has chosen to put the onus on the owner to determine whether the condition exists in their particular vehicle, and not have to service every vehicle in the suspected population. It also appears that the owner must pay for the repair and then claim reimbursement from GM.
ASE expert
My brake light switch keeps going out which makes it to where my brake lights are on until i press on the brakes then the brake light goes off. i have a 06 G6. i have had it replaced two times and it went out again. has anyone had this problem and what can i do to make sure it doesnt keep going out. my mechanic says its the way it is designed but this has happened 3 times in three months! please someone help!!!::eek:
The metal pins in the connectors need to be replaced. Newer cars have plated pins, if the contacts are not 100% you get micro arching and deposits of carbon which is why the problem gets slowly and progressively worse over time. It causes all sorts of unexplainable problems because it's similar to a brown out on your house. Just a loss of partial power. Thanks s why it is so difficult to diagnose. The only way and best way to do any type of diagnostic is a voltage drop test. The best technicians and engineers will know what this is and why it's preferred. If you can figure how much power the circuit requires (1/3 of the fuse amperage) then test the complete circuit and see where your voltage/amperage drop is. Narrows it down real quick. 9 times out of 10, it's a connector pin.
There was a recall on this issue. The brake lights come on by themselves. The dealer is supposed to put dielectric grease on the body module connector. My dealer did that, but they put it on the wrong one. So I kept having the problem of my brake lights coming on by themselves. I took it back and they wanted to replace the brake light switch, which was not the problem. I ended up buying some dielectric grease myself, and put it on the connector. Had to do it it a couple of times. This was on my 08 G6 GT.
My brake light switch keeps going out which makes it to where my brake lights are on until i press on the brakes then the brake light goes off. i have a 06 G6. i have had it replaced two times and it went out again. has anyone had this problem and what can i do to make sure it doesn't keep going out. my mechanic says its the way it is designed but this has happened 3 times in three months! please someone help!!!::eek:
It sounds like you have a short/crossed wire in your tail lights .Are all your parking lights/ tail lights grounded properly ? If that does not work, I would change the brake light switch With a Different Brand.
There's a recall for the brake lights my fuses kept blowing turns out that was the recall got it fixed for free
Brake lights stuck on
Well I've got a fairly serious problem with my 2005 G6 GT. Whenever the car is running my brake lights are stuck on constantly whether I am cruising, accelerating, or even just parking.
I've seen this problem posted with a few other G6 owners across the Internets but no one seems to have a solution.
Has anyone come across this or does anyone know of a solution? Dealerships seem to like to replace the brake switch and nothing more, wether it helps or not. I hope I can get this fixed soon, I do not want to be pulled over. :(
Im having the issue with mine ive done some research that some times the body control module can have a bad connection to the computer......check the bcm wiring harness or the fuse box located in the truck and check the stop lamp relay as well
