My alarm is currently broken, i know all i have to do to get it fixed is re-solder the insides, easy job.
The thing is my car alarm is still engaged, and i know i can manually open the door using the key.
Will my car even start if i do open it with the key? And will the alarm go off once i open the door or start it up?
Yup, the key has an RFID chip inside that communicates with the cars computer, When you open the door the car should start honking but in a quiet kind of way for a little bit before it goes into full loud-ass violation mode, Simply get in, put the key in the ignition and start the car. The alarm should shut up and everything will work fine.
I had to solder the battery clip in my remote, it was easy as pie. Pretty simply and quick
