I know I've seen this topic once before, but I have just had this issue arise with my 07 G6.
Firstly I already have bug build-up inside of the light. Now tonight after leaving my girlfriends house, I realize that I have water lying on my shifter. So I instantly think that there must be water leaking through the sunroof. Shockingly enough, it wasn't the sunroof leaking, it was the light. Water is coming in through the light assembly. Whichever way the bugs are coming in, water is coming in too.
Anyone else having this same issue. If so, we all need to report it to have this issue fixed for no cost.
My son has the same problem with his car. He found water in the lights by the sunroof switch. I am thinking that one of the drain tubes is disconnected or plugged, causing the water to flow into the roof/light area. I left a message on sunroof leaking question to see if that what someone that has fixed it found. I will be checking back here to see if someone leaves you the correct fix. Good luck to both of us...........
