Think I need to replace the cam sensors on my 2009 Pontiac G6 is a 4 cylinder model but the book for my car (Haynes Repair Manual) says that the pcm needs a relearn after the replacement is complete is that the same as reset or something different. I have 6 codes that came up on my scan tool, most seem to revolve around the camshaft position being out of wack. Want to fix this myself if possible I'm a single mother of 3 and definitely not a mechanic but using the book I have replaced many parts and rewired one of my headlights. Looks like a fairly simple straight forward job, I know if I disconnect the battery for a while the computer will reset but will it also relearn what it needs to for this fix by doing it? What to find out before I dig into this so I'm not stranded. Thank you in advance for any advice
I do not see any relearn procedure mentioned for the 4 cyl (but I do not have one). The instructions for the V6 only mention a relearn for the crankshaft position sensor replacement. The 4 cyl mentions an intake and exhaust sensor. The only tip that was mentioned was to use a little engine oil round the o-ring of the replacement(s).
You might want to post the codes as this may help others provide more information. Hope you manage to fix it and Kudos for giving it a go.
I wasn't sure if it was for both or not as the note is located in between the instructions for both and yes I did read that about the oil, do you think I should make a separate post about the codes I have gotten 6 and 4 of them have to do with the camshaft position sensors, and one for the mass air flow performance and the other is for the throttle position sensor 1 performance but my scan tool indicated that the camshaft position sensor is at the highest priority to fix so? And thank you so much for the response anything helps
I've replaced both sensors and actuators on my 2.4, There has never been any relearn process. It just takes a few minutes of the engine running to reset the code, and you should be good to go.
Sweet thanks so much been the only thing holding up my repairs, have to do the cam sensors, actuators, throttle body and I guess a mass air flow sensor and that should take care of the engine trouble I've been having or at least it Should take care of the check engine light 😁 you sir have made my day, many thanks
