I'm changing bushings on my 2008 potiac g6, I've already done struts, the sway bars, and the lower control arm. I'm taking it to the shop for the inner and outer tie rods and an alignment.
What I can't figure out is the triangle brackets behing each tire!!! Does anyone know what that bracket is called? The bushings are shot on those.
'Did sway bars'?
The sway bar runs laterally and has end links that connect to the struts.
The bar is mounted to the frame with these inverted u brackets.
These are sway bar bushings.
You will need to measure bar diameter to order and I recommend a long and short 13 mm ratchet wrench. You can use a non-ratchet, but I tell you, there isn't much room and it gets old to work those bolts.
