I have a Pontiac g6 2007.
I crank my car up today to warm it up and it never happen the gauge didn't even move 5 minutes later the transmission light came on... Need help I don't know what to do
First off what size motor?
Next check that the coolant for radiator is full
Do you mean the Check Engine Light? could be on for setting the code for coolant TEMP too low, which usually means a stuck OPEN thermostat. When this does happen the temp gage will not move and a few other things will not work either, like A/C.
Is the coolant full?
Does the car have heat even though the gauge reads cold?
Did the OBD register a fault code?
