1 - 1 of 1 Posts
I have a 2006 G6 V6. About 5 months ago I went out in the morning to go to work and the car didnt start. So I had it towed to the garage and had to put a new fuel pump in it. I got it back and it worked for acouple days. Then it did the same thing. So I took it back in and this time the fuel pump relay needed replaced. Got it back and it was fine. About two weeks later it did it again, and once again took it back to the shop. He couldnt find nothing wrong so he changed the relay again and also the fuel pump fuse. The next time it happened the mechanic told me that if I pull the fuel pump fuse out and put it back in it will start up. So after he told me that I was pulling the fuse once or twice a week, and it worked every time. Now about a month ago, the car started dying while driving it. When it does i have no gas at all but all other functions work. So I pull over, pop the trunk, pull the fuse, put the fuse back in, and it starts right up. After this started I called the machanic and he put another new fuel pump in because it is now a safety hazard. Its been about two weeks since the new fuel pump was put in, again, and it still has problems starting up. Luckly it hasnt died on the road yet. My mechanic has no idea what to do because he says he never saw anything like this before and I really do not want to take it to a gm dealer without hearing any input and suggestions from anyone. Oh and my air filter is new and I cleaned my air intake, I think thats what its called when you got to buy that spray and spray it into the hose from the air fitler to the engine. Sorry not real smart on the engine. Thanks
1 - 1 of 1 Posts
