1 - 20 of 52 Posts
Anybody else out there with the in dash CD changer having any trouble with it? Every so often mine jams up, I can't eject, play, add, or change disks to it until it cools down for a while. I took it to the dealer and he offered to look at it sometime during the week, but I work 45 minutes away and can't get off work for something like this at the moment.
Just wondering if anyone else has seen this problem with the factory cd changer in the G6.
Hmm..no issues with mine..I keep it playing constantly.. just like everything else..hit or miss item. I would keep CDs out of it until you get it replaced. :(
Today as I had just gotten back into the car, started it up, (after being parked for maybe 20 minutes? already warmed up..) the CD player said "CD player error" and went to the radio, but when I hit source it played the CD's fine, maybe it was just tired and grumpy.. :confused: But that's the most of the CD player issues I've seen..
Just had the issue today you are talking about..I cranked on the A/C and after cooling down it worked again.. Something smelled like it was melting from the heater. (appears to be related to what vent setting you use..) Laura normally uses the vents that blow in your face and I use floor/defrost.. today I was using the same vents laura normally does and the problem popped right up. Dealer time again.
Thats what we get for buying brand new :) bound to be little bugs that need worked out. The more we relate to our dealers and GM the better off the future owners will be. :)
Yup! Just had that issue this morning Got in and the player froze right up couldnt do anything. Im in Buffalo and it got real cold over night(wonder if that had anything to do with it?), its started to work after the temp went up. Called the dealer this morning. taking it in first thing monday. will let you know what happens.
I think I jinxed myself! This morning it got all jammed up again...now it's just cycling trying to load disc 1 - all I did was eject disc 6 and it got all screwed up!
Anyways took it in to the dealer on my way to the office and they are replacing it AGAIN! on Monday.
Store bought at this time. Today I messed with it a little....it ejected 2 CD's at once???? I was kinda puzzled...
Since then though nothing has worked...it wont play the remaining 3 CD's. I finally got it to stop cycling...it kept trying to do something. Once it spit out the 2 CD's it stopped....
Ahn...we'll let the dealer replace it again....Actually my dealer told me this morning they are having problems with them. They aren't sure what can be done right now.
SBM.
Well, I did testing on these radios at my old job, and they definately jam up when operating in temps over 40C and below 0C...just beware, they also tend to scratch the discs at these temps when they are trying to change the discs...
1 - 20 of 52 Posts
