I recently bought my mother's 2.4 L 2009 Pontiac G6 with ~135,000 miles on. As far as I know, the only issues with it before this past weekend were the tire pressure sensors (I think two of them had their batteries die) and the traction control (which would turn off every once in a while but would turn back on; from Googling my issue, I think this is pretty common?).
Since getting the car, I've only put on a hundred miles or so without issue. That is, until this past Sunday, when I got a mile or two from my house. At that point, the traction control light came on, so I slowed down. The light went off, so I accelerated back to speed, though I noticed it was a bit hesitant to do so. The light came back on, I slowed down again, and at this time it became apparent that the car was losing power, so I pulled over and turned the car off. When I turned the car back on, the TC warning light was still on, but now there was the CEL, and the engine was shaking like an unbalanced washing machine while in idle. When I put it in drive, I managed to get maybe a block down the road before the engine died.
At this point, I had the car towed home so I could borrow an OBD reader to scan for codes. I tried doing that today, and the reader was not able to communicate with the computer no matter what I did. I also had some new issues: there’s a message of "ERROR" alternating with the total odometer reading and the gas gauge bounces up and down from a quarter tank to empty (though the car starts). I think the infotainment center also says that power steering is off, but there's no corresponding light on the dashboard.
So that's where I am at: I've got a G6 with a CEL, a fuel gauge that goes up and down, and an engine that shakes very roughly at idle, but I can't get any codes to diagnose what might be wrong. I have tried disconnecting the battery for a few minutes, but that didn't seem to do much. I do have some Iso-Heet on hand in case this could be the result of some water vapor in the gas tank, but I'm not sure that would be triggering so many issues at once. Any thoughts of where to proceed next?
