I have been experiencing a rattle/click in my front right end for a few weeks now, it happens when I hit any bump, no matter the size or speed. I can make the noise happen by pushing the front right side forcibly down, and it makes a "click" (moderate tone). I popped the hood and repeated, and I couldn't see where it was clicking. And the MM was holding still, so I ruled that out. Any insights would be nice.
Perhaps some dryness in the little bearing on the top of the strut?
Or maybe you have a ball joint or tie rod that is starting to go out.
Maybe try jacking up the entire front end and wiggling things around to see if you hear anything similar.
I should have a chance to jack it up this weekend.. Thanks!
Check the endlinks as they seem to make noise as they get old
I have the same issue for a while now. In my front right. It's so annoying. I just changed my struts and tie rod ends and its still Mali.g the noise. I think it may be the sway bar end link bc its wore out but I won't know until I change it.
